Aluminum question
Old Apr 27, 2011 | 03:44 PM
B.M.'s Avatar
Default Aluminum question
The aluminum pulleys i installed a few days ago dont exactly match each other and i want to try and fix that haha.All of the pulleys are a satin type finish except for the power steering pulley,it is very bright polished.I know i could polish all the others to make them match,but i have an easier idea.What is the best way to unpolish aluminum,way i see it is it would be alot less work to make 1 match the others rather than trying to make the other 3 match that one,so what is the best way to take a polished part down to a satin type finish and still have it look good?
Old Apr 27, 2011 | 09:36 PM
A Scotchbrite pad will knock the bright polish off, and leave it satin. If you're VERY CAREFUL, you could hold it to the front of the pulley while idling the engine and it will give a better satin, as the pulley rotates to get an even finish.
Otherwise you can simply pull the belt and turn the pulley by hand as you burnish with the Scothbrite pad.
Old Apr 27, 2011 | 09:37 PM
gfrench's Avatar
yep, or 0000 steal wool
Old Apr 27, 2011 | 09:48 PM
Yeah, the steel wool is a good idea too!
Old Apr 28, 2011 | 12:35 AM
Slip a 1/2" bolt in your pulleys center hole and jamb nut it down. The lock the drill in a vise or hold in some safe way. Put a zip tie around the trigger. Then use red scotchbrite, I'd bet you pulleys are clear powdercoated though. It may get ugly before they look good.
Old Apr 28, 2011 | 08:12 AM
Good point Damon! If they're clear coated you might have to sand them to get the clear off first. Maybe you might just want to leave it shiny.
Old Apr 28, 2011 | 06:47 PM
B.M.'s Avatar
Yeah,i didn't even think about the clear coat,so i may just leave it alone then.Besides with them all installed in the car,unless you shine a light down on them it's hard to tell one is shinier than the others,plus they will be dirty soon so it will be harder to tell haha.
Old Apr 28, 2011 | 08:14 PM
Dirty!!!!???? You'll be under there every so often wiping and cleaning, so they'll never get dirty! At least I bet you will! I know I do!
Old Apr 29, 2011 | 07:27 AM
B.M.'s Avatar
Yeah definitely going to be wiping and cleaning every once in a while,but if the dirt helps make them look like they match then the rag may have to bypass the pulleys haha.
richard.nelson100
Dec 31, 2011 03:28 PM
Mikey.
Sep 13, 2011 11:39 PM
jessedgraham
Jan 16, 2011 01:04 AM
97blackcamaroRS
Oct 3, 2010 10:59 PM
The Banks
Mar 7, 2008 04:15 PM
