79 camaro blinkers acting up i need some help!!!
Old May 30, 2009 | 01:37 PM
stenny's Avatar
Default 79 camaro blinkers acting up i need some help!!!
ok i just got the car i know a good amount about cars i am educated a little bit so i put on my right blinker it works fine i put on my left blinker it stays lit doesnt blink i tried changing the blinker thing on the fuse panel did the same thing also my hazards dont work at all!! so what happened to my car and how do i fix it its a 79 camaro i think it has a 305? so can you help me?
Old May 30, 2009 | 01:52 PM
Your blinker thing works both sides of your turn signals, that's why it wasn't that. Have you checked to see if you have any burned out bulbs in your front or rear light assemblies?
Old May 30, 2009 | 06:26 PM
stenny's Avatar
well they all light up but just stayed lit
Old May 30, 2009 | 10:06 PM
Check your grounds (mounting points) at the lights, the ones that aren't working right. One of them might not be getting a clean ground to the body.
Old May 31, 2009 | 09:12 AM
stenny's Avatar
Ok I will check where are the grounds located?
Old May 31, 2009 | 09:15 AM
stenny's Avatar
Also my headlight fell out how do you get them back in?
Old May 31, 2009 | 12:23 PM
breakstuff6190's Avatar
Thumbs up
you have to fill them back up with headlight fluid before they will stay in.
well, im not sure on camaros but on other cars where i have worked on the lights and blinkers, the blinker system runs through the hazard switch. you said that your hazards dont work at all so it could be your hazard switch that is malfunctioning and not only causing your hazards to not work but also your blinkers. try disconnecting your hazard switch completely and then trying your blinkers. if none of your blinkers come on, then they do run through the hazard switch and i would replace that then go from there. if disconnecting your hazard switch does not effect your blinkers, then there is probably a short or a miswiring.
if they work after you replace your switch, great! if not, there is probably a short or a miswiring. hope this helps.
and there is a spring that holds your headlight in, btw.
Michael J. Kelly
Jun 27, 2014 08:11 AM
Vanman
Aug 17, 2010 06:06 AM
camaroFaST
Jun 25, 2009 05:14 PM
camarofreak1990
Sep 4, 2008 09:29 PM
stitch85
Jul 9, 2006 10:52 PM
