'79 Camaro Berlinetta Project Help
Old 11-05-2009 | 06:22 PM
JD79Camaro's Avatar
Default '79 Camaro Berlinetta Project Help
I just picked up a '79 Camaro Berlinetta and it is just a rolling chassis. It had a 305 in it and I have a big block 454 I'm rebuilding. What type of motor mounts do I need? Does anyone know where I could purchase them. What would be a good transmition to put in it also? If anyone knows of a good place to get replacement parts for the car your help is needed.
Old 11-05-2009 | 07:38 PM
You need to leave the stock frame mounts, and use a set of motor mounts for a small block V8 to install the 454.(any 350 mount). As for buying them, you can get them at any local NAPA, unless you want solid Moroso, or polyurethane mounts.
Old 11-28-2009 | 10:29 PM
uestraven's Avatar
The stock mounts are compatible with big-blocks and small-blocks. As for tranny try throwing a TH-400 behind that sucker.
Old 11-30-2009 | 06:59 PM
thatcamaro's Avatar
go to groundup.com you can get every part for the 79 from the catilog.
Old 12-01-2009 | 08:26 AM
ATM's Avatar
ATM
http://www.ss396.com/
Actually tried it. This is the correct site.
Old 12-01-2009 | 07:03 PM
Their prices aren't too bad from what I see.
xxSithRagexx
07-01-2014 12:26 PM
89gmc
06-03-2011 07:50 PM
79 Berlinetta
09-02-2009 05:40 AM
hellraiser5010
82-92 V8 Tech
08-15-2008 06:45 AM
ricozero
05-07-2007 12:05 AM
Quick Reply: '79 Camaro Berlinetta Project Help
