78 camaro power window switch help
Old Dec 13, 2010 | 09:37 PM
will1987's Avatar
Default 78 camaro power window switch help
Hi am trying to reconnect the dual power window switch that goes in the center console back up.Well i just need help figuring out how each wire connects theres 5 wires that go to the dual switch gray,brown,pink,blue/white,dark blue i just need some help on knowing how to reconnect them put my windows down thanks.
Old Dec 13, 2010 | 11:01 PM
I think Joe has a diagram he can post. If you ask nicely I'm sure he will.
Old Dec 14, 2010 | 02:59 AM
80ZJoe's Avatar
July 2010 ROTM
lol, i sure do. See, thats why that thread should be a sticky
Old Dec 15, 2010 | 03:12 AM
will1987's Avatar
thanks sorry am new i just tryed hooking the switch up but no luck any other advice the diagram doesnt show a gray wire or am i just not hooking them up right ?
Old Dec 15, 2010 | 09:46 AM
Get yourself a test meter, or just a 12v. test light. Put the test light on each wire and then ground the clip. When the light comes on that's your power feed. Then just hook the other two wires to the switch in any order and try it. If it goes the wrong way just reverse the other two.
If you can't get any of them to illuminate your test light, then check to see if you have a bad fuse or broken connection on the 12v. hot.
pcarollo
Jun 21, 2014 10:13 AM
Chevy101
Oct 7, 2011 03:49 PM
pooter_07
Dec 31, 2010 11:51 PM
camaroglen
Aug 28, 2010 08:58 AM
foxforcefive
Sep 9, 2008 05:03 AM
