73 castor angle
Old 03-16-2007 | 06:28 PM
a5llx's Avatar
Default 73 castor angle
Hi can anyone tell me what the castor angle on a 73 camaro should be standard from the factory.
Thanks ASH
Old 03-24-2007 | 12:26 PM
v8chvyguy's Avatar
Default RE: 73 castor angle
I'm not sure about 73, but in 79 the specs are +0.6 camber and 1.0 caster. With that said, I will tell you from experience, these settings drive like ****. You want it to drive like it's on a rail? use these specs: -0.2 camber and 2.0 caster on the left side and 2.2 to2.3 caster on the right. You can angle bore the holes in the upper arm to allow more adjustment. the most caster I could get was 1.9 deg. on the left without drilling the holes, it all depends on the car, everyone is different. Remember, the key is the -0.2 camber and 0.2 to 0.3 stagger on caster. I bet you could float between 1.5 and 2.0 caster and it would work.
jwallace1025
07-30-2011 10:14 AM
1971BB427
04-29-2011 08:12 AM
fasttony350
03-26-2011 04:03 PM
Vet76te
12-07-2010 11:40 PM
grndscrpr03
01-27-2005 09:15 PM
Quick Reply: 73 castor angle
