73 camaro clip
Old Mar 19, 2007 | 09:12 PM
a5llx's Avatar
Default 73 camaro clip
Hi can anyone tell me if the ball joints and bushes are interchangable between all camaro clips up to a 75,my clip has the steering box in front of the crossmember but up till now this is the only difference i can make out from loads of pictures ,areall the arms etc the same as they look itto me?!
Also is there a rack i can use with a standard clip to lose the steering box , as i have fabbed the clip intomy 50 3100 and want to losethe box without getting bumpsteer in the process .
Thanks guys , ASH
Old Mar 20, 2007 | 12:14 PM
rat454's Avatar
Default RE: 73 camaro clip
The 2nd gen camaro front suspensions are basically all interchangeable.
I haven't been able to run down a kit to put rack and pinon in a 2nd gen.
What's are your issues with the stock steering from the camaro?
G
Old Mar 20, 2007 | 05:15 PM
a5llx's Avatar
Cheers for the info, what ive done is cut the crossmember ouof the camaro one , boxed my truck chassis and welded the crossmember into the truck chassis, that supplied the front lower mounts and engine mounts , then i fabricated the lower rear mounts and top mounts , so now the steering box will not bolt upto the frame as the the truck frame is narrower than the camaro.so now ive got to find a rack that will mount in front of the crossmember with a measurement ofapprox 60cm between swivell joints , is it 100% critical that this width is perfect to illiminate bumpsteer?
apparently the width of a jag lh rack is 28cm from the centre of the rack to swivel joint so i take it this may do, am i right? i have so many questions i dont want to get it wrong! for example could i put the lh hub on the rh side so i can mount a rack on the back or would this change the castor angle etc ?
Thanks ASH
Old Mar 20, 2007 | 09:57 PM
rat454's Avatar
Steering geometry is way over my head...but I would wager that it's best left to experts....
Might check with art morrison at http://www.artmorrison.com/ if anyone can steer you in the right direction those guys can..
G
Old Mar 21, 2007 | 06:35 PM
a5llx's Avatar
hi just fitted up all the arms and hubs etc , they are not interchangable! i may have worked out a way to modify the original steering setup which would be nice ill let you know if it all goes Pete Tong! thanks ASH
camaro396
Jul 27, 2015 10:30 AM
Tevin '95
Oct 24, 2009 02:46 PM
mustarogz69
11
Feb 25, 2008 08:37 AM
a5llx
Feb 26, 2007 03:47 AM
