72 RS project Z28 clone
Old Jan 3, 2007 | 01:48 AM
55chevy's Avatar
Default 72 RS project Z28 clone
This car was advertised as a 1970 Z28, but turned out to be a 1972 with 307, oh well, I've always loved RS since 1975 when my sister had one. Has a full drag race 82 decked engine with 1969 302 roller rocker heads, race cam. frame connectors, fuel cell,yada yada, MSD and all that stuff, I may just sell engine /4000 stall tranny and get a milder street engine that cruises easier. Needs complete interior, has roll cage that messes up the rear shelf and back seat, maybe I should drop engine in and see how fast it goes?
http://s115.photobucket.com/albums/n291/57charley/
Old Jan 3, 2007 | 03:08 AM
74454bb's Avatar
May 2007 ROTM
Default RE: 72 RS project Z28 clone
looks like alot of work, keep us posted on it. and let us know how fast.
Old Jan 6, 2007 | 07:45 PM
55chevy's Avatar
Pictures http://s115.photobucket.com/albums/n291/57charley/
1982 Chevy truck block bored .40 over, top of block is zero decked
Balanced rods and pistons heads shave .120 and 23 degree angle cut
Intake matches the block Harland sharp roller rockers, manley valves,
Comp valve springs, yo ucan go up to .600 lift cam heads are 69 Z28 202
Lunati cam 545 lift 301 duration 104 lobe seperation Lunati lifters
Pete Jackson timing gears set 4 degrees BTDC
NF balanced crankshaft 20/ rods 20/ mains
750 Holley carb turbo 350 TCI AT w/4000 stall convertor
410 rear end gears Richmond center moser axles
Lakewood ladder bars frame connectors driveshaft loop
S2K1
Nov 13, 2021 08:29 AM
69yenkocam
Nov 15, 2007 09:40 PM
350rs
Mar 15, 2007 02:10 AM
