71 ss 396?
Old Mar 28, 2012 | 07:44 AM
OAKTREE's Avatar
Default 71 ss 396?
just picked up a 71 camaro that im trying to decode. it is a lime green norwood built 4speed with no motor. the trim tag says L34. it doesnt say anything else where the rpo would be. i thought that it would say z27 or something that would confirm its a ss. any help?
Old Mar 28, 2012 | 08:05 AM
L34 on the trim tag is the code for SS 396, 350 hp. That's what your car is/was.
Z27 is the SS 350 code.
Old Mar 28, 2012 | 08:08 AM
OAKTREE's Avatar
thanks 69 but shouldnt there be another set of numbers for the rpo. all it says is the L34 nothing else?
Old Mar 28, 2012 | 08:11 AM
No, that would be it: 1971 Camaro Trim Tag Identification and Decoding
Old Mar 28, 2012 | 08:18 AM
OAKTREE's Avatar
ok thanks so much for your help. i think it was a cool car with what i have seen on this car. wish it had motor n trans to tell for sure. has front and rear spoilers green interior,green top,discs up front. it is a barn find that is pretty rough but complete minus motor n trans. any idea what it may be worth?roughly
Old Mar 28, 2012 | 08:31 AM
That's kinda hard to say without seeing it. It also depends on how rough is rough. If it has more rust holes than solid metal, then it's mostly worth the sum of it's usable parts. If the body is pretty solid, and what it needs is paint, interior and engine/trans, then that's a different animal. It could be worth anywhere from a few hundred to a few thousand, it depends. Solid rollers in primer gotta be worth at least $3k. Yeah, that car is an SS model, but the original numbers matching engine is what truly makes it that. Too bad the car was cannibalized.
Old Mar 28, 2012 | 10:30 PM
FWIW they all had disc brakes.
