70 1/2
Old Jul 24, 2009 | 05:55 PM
bhiz21's Avatar
Default 70 1/2
nothings really original in this car.. i think it has a 350 in it v8 someone along the line put a 3 speed into it. i'm looking to see what transmissions i can get for it to stretch out the speed over its now around 70 mph
Old Jul 24, 2009 | 08:19 PM
what yr, model car, auto or manual trans? pictures? welcome to the forum.
Old Jul 26, 2009 | 10:41 PM
bhiz21's Avatar
1971 camaro . manual 3 speed. pics soon.. i figure its a 350 not sure
Old Jul 26, 2009 | 11:52 PM
how many rpms at 60 mph. who would put a 3 speed manual in a camaro? should be a crime.
Old Jul 27, 2009 | 01:09 AM
Originally Posted by craby
...who would put a 3 speed manual in a camaro? should be a crime.
GM would, back in the day. The Camaro (and other models) was available with either a three speed or four speed manual trans.
Old Jul 27, 2009 | 11:08 AM
bhiz21's Avatar
its prolly at 4-5 thousand.. no rpm meter
Old Jul 27, 2009 | 12:15 PM
if the clutch is not slipping then i would say u have a 4 speed trans and only making it to 3rd gear or u have a really low ratio rear end. 456 or 512. jack the back of the car up (both wheels) block the tires for safety and put in nutural and spin the wheel. if both wheels spin the same direction u have a posi and can do this by your self. if not it will take two people. spin the tire 1 revolution (both wheels need to turn the same direction) and count the number of times the drive line or shaft turns. if it turns about 4 and 1/2 times its a 456, a little over 5 and its 512. if it turns about 3 and 1/2 times its probly 342 and u are not getting to 4th gear or the clutch is slipping.
Old Jul 27, 2009 | 09:04 PM
bhiz21's Avatar
there is no fourth gear its just forward to the left is reverse, back left 1st top right 2nd back right 3rd thats it.
Old Jul 27, 2009 | 10:24 PM
is the clutch slipping? when u punch it does it go right away or does the engine rev up and the car slowly picks up speed. im thinkin its got a really low rear end.
Old Jul 28, 2009 | 08:13 AM
2Slow4You's Avatar
Default rpms
If rear is geared more than 373s I would go with a 5 Speed tranny.I'm running a 5 speed in my 70 nova.5 speed came out of 84 camaro, Running hydraulic clutch pedal.Main issue i had in conversion is had to modify header to install clutch cylinder to tranny.Every thing else was very simple.5 speed allowed good take off and cruised at 2000 rpms at 70 miles per hour.Just something that worked very well for me.
