2nd gen suspension set up for canyon carving
Although I have my suspension already set up to handle the canyons, I was wondering if anyone else has some different(budget) combos that work for them -- I might want to try some other set ups and see if they work any better than what I have now -- currently running: poly bushings front and rear including sway bar mounts,end links and frame bushings, quick ratio strg box, 1-1/8 bar frt and 7/8 bar rear. 450lb guldstrand frt springs(about 3/4 coil cut off) and de-arched rear springs rated at 200lb. and very much needed frame connectors. Anybody out there got something better. the mistress handles pretty good now but I'm always looking for more ways to scare myself..........
Thanks for the reply. I should have gone with the delalum bushings during the build but had to cut corners. I'm thinking of installing them in the future possibly will try tubular control arms for the frt as well. Do the g-bars bolt in between the control arms and firewall or am I thinking of something else?
2nd, bar, california, camaro, canyon, carving, dave, fbody, gen, heard, protouring, setting, soft, suspension, sway
