2ND Gen hood clearance on Big Block Swap
![Cool](https://camaroforums.com/forum/images/icons/icon6.gif)
Sorry to ask for advice on old questions, but I'm new to Camaros and I'm putting a 454 in my '79 Z-28 and would like to reuse my stock hood. I plan on a modest build using an Edelbrock RPM intake, Holley carb, and a traditional open element air cleaner. Will I encounter fit problems when I close the hood? If so, can I cut out some of the sheet metal on the hood itself and then have it fit under the Z-28 hood scoop? I'm sure many of you out there have done this. Maybe some even have dimensions as to where to cut, general advice , etc. Thanks for any advice.
I have a big block with an Air Gap intake and there's no way i could reuse my stock hood. I have a 4" cowl hood
My '71 came with a big block and stock hood, and I changed to a aftermarket intake so I had to change hoods at that time. The stock Chevy low rise works well for most applications, but is not a high rpm intake, as it's good to around 5,000 rpm's.
I see them on Ebay often, but they were all for spreadbore carbs, so don't go that route if you don't want to use a spreadbore Holley or Edelbrock carb.
