1st or 2nd Gen better?
Old Sep 8, 2006 | 01:27 PM
Silver02's Avatar
Default 1st or 2nd Gen better?
I've got a 74 Camaro that I want to put a big block in with a turbocharger. I'm thinking of getting a 1st gen but I'm wondering which one has a larger engine bay?
Old Sep 8, 2006 | 05:51 PM
Blade's Avatar
June 2007 ROTM
Default RE: 1st or 2nd Gen better?
1st gen u can make bigger by taken out the fender wells but u have to make sure u have clearance from the header to a arms tight fit for a bb. not ure about 70 style
Old Sep 14, 2006 | 03:59 PM
1969 SS's Avatar
you can fit it in either. a friend put a twin screw set-up on a 502 in a 69 so if money isn't an issue, it shuold be a no-brainer. 1st gen all the way baby!
Old Sep 14, 2006 | 05:41 PM
74454bb's Avatar
May 2007 ROTM
I have a 74 with a big block, there is a little room left,but the same goes if you drop the wheel wells. If you have the money it will fit.
Old Sep 25, 2006 | 03:22 PM
uncle bill's Avatar
I think the 1st gen will allow more hood clearance but other than that, They're about the same. The 1st gen will be a little lighter also.
Old Sep 26, 2006 | 02:17 AM
Silver02's Avatar
1st gen will be my choice but I hate that they're so freakin expensive compared with 2nd gen especially since I've already got the 74.
Old Sep 26, 2006 | 01:38 PM
81CanuckZ's Avatar
If money's not an issue, stick with the 2nd gen. You already have it, it's slightly more aerodynamic as a drag car, and you see more 1st gn draggers so your 74 will be more unique..
Old Sep 26, 2006 | 02:05 PM
74454bb's Avatar
May 2007 ROTM
I would keep the 74 as well,with both car's you would need a cowl hood. If your not a big fan of the bumpers,then just paint them to match the car. Other then that,at least you have the rear window of the 70-73 car's.
