1979 Z28 Build
Old Dec 2, 2010 | 06:22 PM
  #41
wolfocaster's Avatar
Oh, I dont know much about body work so i'm getting that done. I am going to do as much of the interior as I can though. Are you doing all of yours?
  #42
DarkKnight's Avatar
GTO Killer
LimeKnight
im going with the holley 770 street avenger carb, from reviews the people love them, easy to tune, with all the extras =]
Old Dec 2, 2010 | 06:33 PM
  #43
Cool man, Mech secondaries or no?
Old Dec 2, 2010 | 06:35 PM
  #44
DarkKnight's Avatar
GTO Killer
LimeKnight
umm im not sure on that one
http://www.holley.com/0-86770BK.asp
Old Dec 2, 2010 | 06:41 PM
  #45
Ok, i'll check it out. Thanks for the recommendation. I just want mechanical secondaries so they will be there regardless of vacuum.
Old Dec 2, 2010 | 08:05 PM
  #46
The Street Avenger series use vacuum secondaries. Unless you're building a all out race engine that you want to also drive on the street you'll want vacuum secondaries. On the average hotrod engine mechanical secondaries will cause a bog if you mash the throttle in a low vacuum condition.
With vacuum secondaries the engine reaches peak vacuum and brings in the secondaries as the vacuum optimizes. Much more low end power, and better throttle response for street vehicles.
Old Dec 2, 2010 | 10:32 PM
  #47
DarkKnight's Avatar
GTO Killer
LimeKnight
exactly why i need it =]
Old Dec 3, 2010 | 12:06 AM
  #48
Hey, you got a nice little small block there. But I have just one question. Why spend all that money and the cheap out on the timing chain? Its like you have all these nice aftermarket parts (roller rockers) then the cheesiest timing chain you could get.
Old Dec 3, 2010 | 05:03 PM
  #49
BenL07's Avatar
so forgive me for sounding like such an idiot but what exactly would a "low vacuum condition" be? because sometimes if i hit the gas from a stop light my car bogs down
Old Dec 3, 2010 | 05:11 PM
  #50
DarkKnight's Avatar
GTO Killer
LimeKnight
you have the wrong carb,,, your stop light is your low vacuum condition, theres no pressure built up, once the engine is up in higher rpm vacuum is created, high vacuum condition where the mech secondaries are more needed
