10 BOLT 12 BOLT
Old Sep 12, 2006 | 08:31 PM
SABSCAMARO's Avatar
Default 10 BOLT 12 BOLT
Hi, I was wondering what is the differences between a 10 bolt or a 12bolt. I'm still in the learning stages. Thanks
Old Sep 13, 2006 | 12:36 AM
GRIFF's Avatar
Default RE: 10 BOLT 12 BOLT
GM made at least two versions of the 10 bolt the 8.5 inch and the 7.5 inch(ring gear) the 8.5 can be a fairly stout piece the 7.5 is not. GM also made 2 versions of the 12 bolt one is a car 12 bolt with a 8.875 ring gear and the other was a truck rear . The 12 bolt is stronger than either of the 10 bolts, and there are those who argue it is stronger than the ford 9 inch in stock form(it uses less power to turn than the ford and is lighter but is not as convienent for gear changes as the ford) I know you didnt ask about the ford but it is a very common performance conversion and can be made to be very strong. I think gm also made an 8.2 10 bolt also but I dont know to much about it.
Old Sep 14, 2006 | 04:12 PM
1969 SS's Avatar
unless you are constantly racing a 8.5" 10 bolt is going to be fine. I know guys that go 10s all day in their 10 bolts, not that I would trust it but they do
12 bolts are getting to be way over priced
Old Sep 14, 2006 | 07:37 PM
GRIFF's Avatar
I think the 8.2s were in the first gen from what I have read they are not a real strong unit. I think where the 10 bolts have gotten bad press is from the 7.5 and 8.2 units.
Old Sep 17, 2006 | 01:27 PM
SABSCAMARO's Avatar
THANK YOU GRIFF AND 1969SS, I GUESS I'LL KEEP THE 10BOLT.
Old Sep 18, 2006 | 12:48 PM
1969 SS's Avatar
you could also buy a stud girdle cover for your 10 bolt to strengthen it up. I did and it definitely helps, plus it looks COOL
timopajala
Feb 22, 2017 07:27 PM
MBlac649
Jun 17, 2013 05:51 PM
MS69 YENKO/4-SPEED
Jun 22, 2010 05:07 PM
bivens8314
Jan 10, 2009 04:09 PM
gozzy341
Nov 4, 2007 08:52 PM
