Looking for a little help on a spinning fender bolt
Old 04-22-2019, 10:06 PM
BingHawk's Avatar
Default Looking for a little help on a spinning fender bolt
Doing a tear down of a 69 Camaro that is super rusty. When I went to take the top drivers fender bolt out (the one behind the door when its closed). It started spinning about half way out.
I looked in the assembly manual but I can't tell if there is anything accessible on the back side of this bolt. or if this is something that's going to require welding work to repair. I will find out eventually when I start stripping the dash out. But I was hoping someone here knew. PIc included for reference of what bolt i am talking about. Thanks in advance for any help.
Old 04-24-2019, 09:01 AM
BingHawk's Avatar
I did find out its a caged nut that is enclosed, sounds like the only way to repair is to cut a hole, weld in a new cage nut and seal it back up
swfladad
06-15-2015 11:57 AM
baarf
82-92 V8 Tech
07-30-2010 10:31 PM
edog2
03-23-2010 09:30 PM
raysean22589
02-21-2010 10:22 PM
frostlime69
67-69 V8 Tech
16
11-09-2008 09:20 PM
Quick Reply: Looking for a little help on a spinning fender bolt
