New radiator not cooling
Old Apr 20, 2014 | 03:07 PM
S.O.B's Avatar
Default New radiator not cooling
Just did and engine swap in my 69. It's now got a 755hp 582. I bought a 4 row champion radiator with dual fans off ebay fans are supposed to be 1250 cfm each. At cruising speed the car will maintain around 190 for a while then slowly starts to climb the longer you run it at idle the temp goes up steadily at 55mph the car will hold 210 for a while then start to rise after about 10 minutes now that I drilled a hole in the thermostat Do I need different fans? Radiator? What do y'all think?
Old Apr 20, 2014 | 03:28 PM
MKCoconuts's Avatar
Can you hear the fans kicking on? Also, do you have them set up as pushers or pullers. Could always try a lower temp stat.
Old Apr 20, 2014 | 04:59 PM
S.O.B's Avatar
Their pullers and yes their turning on
Old Apr 21, 2014 | 10:21 AM
Everett#2390's Avatar
As suggested in other forums, try an OE style 7-blade fan with clutch and OE shroud.
Old Apr 21, 2014 | 11:31 AM
S.O.B's Avatar
Lol thanks but There's no way I'm gonna fit an OE fan and shroud in this thing
Old Apr 21, 2014 | 01:18 PM
flat tire's Avatar
could you show a picture as to why not
Old Apr 21, 2014 | 02:43 PM
Are your fans mounted directly onto the radiator, or on a flat aluminum shroud that mounts to the radiator? If you have the shroud, you might want to try going without it. I know 2 guys who had similar heating issues like you did, and after suggesting they remove the shroud (mount the fans directly on the radiator), the heat problem was cured. The flat shroud surrounding the fans acts like a blocker, stifling air movement. Now, if that shroud was tapered out to each fan, then you'd have more of a funnel effect where the fans can pull air through the entire dimension of the radiator. Of course, if your fans are already directly, that blows that idea.
Old Jun 6, 2014 | 11:31 AM
Smee78's Avatar
I'm going to guess that your running the correct mixture of water and antifreeze? What about one of the water wetters that are designed make your setup more efficient? Also are you sure you worked out all the air in the system?
Old Apr 23, 2015 | 10:02 PM
jamess411's Avatar
I am having the same issues with a Champion radiator as well with my blown 420 sbc in my vette. Starting to think it might be the radiator
Old May 7, 2015 | 07:12 PM
The 4 row cores don't cool as well as two 1" rows do. And I agree with Chuck's theory of removing the shroud. I had one on my radiator with a BBC, and before installing it the car ran a little too warm. After putting the shroud on, it overheated so bad that I had to do a roadside removal of the shroud, so I could get home!
MsElla
May 27, 2013 03:40 PM
evilmnky45
Aug 3, 2010 11:31 AM
ScottD
Aug 30, 2009 03:24 PM
ok.f-body
May 29, 2009 12:03 AM
SbC89CAMARO
Nov 30, 2006 09:33 PM
