Help with 3932418 valve covers
Old Jan 1, 2014 | 06:27 PM
Harps's Avatar
Default Help with 3932418 valve covers
I've got a set of what I believe to be are original 3932418 vc's.
Both are stamped p-3932418-RH. Then a couple other markings. I'll post some pics shortly if it will help.
My question is, are both the left and right the same cover? With one having the actual hole for the oil fill and the other having the knock out metal blank still installed under the sticker? I just want to verify these are in fact an original set.
In the picture below, you can see the top cover still has the metal knockout installed under the sticker. This is what I want to know, if its original or not. For the pair to be like this.
Here's the stamping on the inside of one of them.
Thanks,
Rob
Old Jan 1, 2014 | 08:23 PM
Yes, same numbers. Those came on the 1969 Z/28 302 and 1969 Corvette 350/350 hp engine.
viperffx
Oct 11, 2010 09:57 PM
rockstarbass1
82-92 V6 Tech
Nov 2, 2009 10:23 PM
SSPOWER
Apr 28, 2008 02:48 PM
blink18236dude
Mar 16, 2007 01:48 PM
nnickty
Aug 22, 2006 02:25 AM
