Engine Oil for 383 Stroker
Old Jul 18, 2011 | 12:19 PM
fastb's Avatar
Default Engine Oil for 383 Stroker
I just picked up a 68 camaro with a 383 stroker. From the research I have done I have about decided to go with a conventional 10W30. I do know the heads are Edelbrock Permorer RPM, but do not know what the cam is along with the rest of the valve train. What do you guys suggest as a safe oil to use in this application? Also, It has a 4 core aluminum radiator and I have read it is perfectly safe to run standard anti-freeze and distilled water 50/50. Double checking never hurts.
This is my first carbed engine, have always delt with LSX engines so I want to make sure I am doing everything correct.
Thanks
Old Jul 18, 2011 | 12:46 PM
Pacop1105's Avatar
Mobil 1 Synthetic 10W30.
Old Jul 18, 2011 | 01:37 PM
fastb's Avatar
should I go synthetic? why synthetic vs. conventional?
Old Jul 18, 2011 | 03:34 PM
If your engine is using flat lifters, you may want to consider using one of the oils now being marketed for old muscle cars. These oils contain zinc, phosphorous and molybdenum for the protection of flat lifter cams. These additives are no longer used in most engine oils because newer engines no longer need them, as they are equipped with roller lifters.
Old Jul 18, 2011 | 06:32 PM
Pacop1105's Avatar
Synthetic oil is better then conventional because synthetic is desighned not to break down as easily and can wit stand extreme temperatures weather it's hot or cold. But if you are using flat lifters You shouldn't use sythetic because it is to slick.
Old Jul 18, 2011 | 08:19 PM
fastb's Avatar
so I could just play it safe for now and use the oil with the zinc in it until I take the time to check the lifters? Is the Valvoline VR1 Racing Oil a good recomendation or overkill?
edit: did a little more reading and it sounds like VR1 in 20W50 is a good choice for a stroker
Old Jul 18, 2011 | 10:17 PM
Pacop1105's Avatar
Yeah play it safe with the zinc until you check the lifters. Yeah the valvoline VR1 20W50 is good.
Old Jul 19, 2011 | 07:49 AM
fastb's Avatar
Thanks for the help
Old Aug 19, 2011 | 10:19 PM
brownstone101's Avatar
20W-50 valvoline VR1 race oil, with a zinc additive. thats all i use, because i want my motor to last, never use SN rated oil, it will mess your motor up big time.
Old Nov 26, 2011 | 02:48 PM
bad436z28's Avatar
Default oil
theres only one oil i will ever put in my car and thats shell rotella,run it even in my semi,love it in my opinion its the only oil to use.they also have syenthetic if thats ur cup of tea.
