Camaro engine code information
#21
ORIGINAL: Ircyklops
This page somewhat verifies that is uncommon, but possible to have a 3959512 block in a '69 Z/28...
http://www.camaros.org/drivetrain.shtml#BlockCast
#22
I picked up one of these short blocks at a local swap meet this weekend & went looking to see what I could find on it. I could not finda 3959512 block listed in any of the Chevrolet by the Number series. So I did a search & found this post. Here's the details: Original shortblock only has been decked so there are no stamped numbers left to read. I should mention here that the guy that I bought it from had torn it down & bored & decked the block. He insisted that the block & crank appeared to have been together all of the engines life. It is a 2-bolt block. Block casting date is I*20*8 which should be September of 1968. 1969 model year. The guy had been told that it was an early 327. But it is a large journal engine. And it is not an early 327 date. Crank casting number is #1182. And that is where it got a little more interesting. According to Chevy by the Numbers, the crank is listed only as a 1967 350/295, forged steel, large journal, aaaaaaaaannnnnnnnnnnnddddddddddd (drum roll) Z28 Camaro only! So at the very least Chevy by the Numbers has a missprint somewhere here. Anyone else have any thoughts on it?
#23
I'd like to share some information on a 3959512 motor that I have in my possession and have known since 1971. It is a CE motor and was put in my 65 Nova in very late 69 or early 70 to replace the fried 327/300. It is a factory 2 bolt small journal, casting date J29, canister oil filter, and it came with domed pistons. It is not a Chevy II block.
I know this because I bought the car from the 2nd owner in Dec. '71, whohad to replace the motor @ ~58,000 miles. I got the car with ~73,000 miles on it.
Now I'm starting to wonder if it's a 327 (that's what I was told) or what?
I apologize for being off topic (Nova/Chevy II), but I have been searching the web for information on this motor and came across your forum.
Mike
Mike
#24
3959512 casting was only a 327 block, 1962-67, and was also used as a replacement block.
http://www.chevy-camaro.com/chevy-ca...es.asp?group=1
#25
No argument that all the resources we've seen/have list the casting as a 62-67 block. I have let Mortec know that this block was cast in October 1969. To others on the list, I was advising them that this block came with domed pistons. It was a factory CE replacement block.
Question: how do I locate the crank casting number?
#26
ORIGINAL: Trbomike
#30
OK, there should be a number cast onto the face of one of the counterweights of the crank, might be on one closer to the front of the engine.
camarocrazy1288
02-17-2010 09:55 AM
