Camaro engine code information
Old Jan 27, 2008 | 11:17 AM
MTH trains's Avatar
Default RE: Camaro engine code information
I see the "512" on your link, but unless I'm reading that wrong that is a 3963512 which is for a big block. Mine is a 3959512. My wife reminded me I had some old paperwork from the Camaro, and she went up in the attic and dug out a couple of boxes of stuff. Many years ago I did get some info. from Jim Schwartz who used to work upstairs in the pattern shop at the Grey Iron plant here in Saginaw. He gave me 24 pages worth of casting numbers for blocks, cranks, exhaust/intake manifolds, differential housings/carriers, cylinder heads,camshafts, and bearing caps. I attached a page from the cylinder block section and it shows a 3959512 in 1968 as a 327cu.in. but it's also listed as change #.
Again I'm still in the dark as to what I have.
Old Jan 27, 2008 | 11:23 AM
MichiganMan's Avatar
January 2008 ROTM
ORIGINAL: MTH trains
dont look at the chart read the paragraph below it it address the 512 block I have just been told that is a rare block definetly has factory vin stamp on it it is a 302 z28 block and the crank 1178 is also used in z28 ( expensive one 2) there is a few guys that put that site i linked for you together One of them guys is corresponding with me about this. They only have (6) of the 512 blocks in there registry. I will pm you the link where this discussion is going on
Old Jan 27, 2008 | 11:31 AM
January 2008 ROTM
this is the paragraph below the chart ........The 3970010 casting was only used during the latter half of 69 Camaro production (for 302 and 350 applications), but the block continued to be produced throughout the 70's for 350 applications and is one of the most common engine blocks. The 3932388 block is sometimes noted as being 'rare', but it actually was commonly used in mid-69 production. Also, there is a 3959512 block that has been found very infrequently in some 69 Camaros. Not much is known about usage of this block, but it is a 4" bore block, thus could have 302, 327, or 350 applications.
Old Jan 27, 2008 | 11:33 AM
January 2008 ROTM
now put that with the DZ stamp which is a factory stamp not a restamp backed up with the 1178 crank you have a 302 z28 block and crank
Old Jan 27, 2008 | 11:45 AM
MTH trains's Avatar
I'm sorry my bad, I did look at the chart and did not read the whole paragraph. I just took a look at the link you sent me and I apprciate all your help. If anyone would like to e-mail me with more info. please do: choochoocharlie65@hotmail.com Also if someone would want copies of the casting sheets from the Grey Iron plant please let me know.
Again, thanks for the help. Scott
Old Jan 27, 2008 | 11:46 AM
January 2008 ROTM
hey I know some guys that would love to have copies of that info or there database's the same guys that put that site together interested?
Old Jan 27, 2008 | 12:21 PM
January 2008 ROTM
Hey scott I would like to see those copies email michaelds59@msn.com close ups if possible
Old Jan 28, 2008 | 11:49 AM
scottlee1's Avatar
appears that someone 4-bolted a 2-bolt. all 512s were 2-bolt 327s
Old Jan 28, 2008 | 01:35 PM
January 2008 ROTM
ORIGINAL: scottlee1
completely incorrect http://www.camaros.org/drivetrain.shtml#BlockCastobviously you didnt take the time to read or look at the pic's
Old Jan 28, 2008 | 01:41 PM
  #20
Ircyklops's Avatar
This page somewhat verifies that is uncommon, but possible to have a 3959512 block in a '69 Z/28...
