What transmission can I use
Old May 14, 2011 | 11:17 AM
Rose350's Avatar
Default What transmission can I use
Im on a budget for my 69 camaro which has 475hp at the crank. The aftermarket transmissions I have found such as monster transmission and tremec are above my budget. I was wondering if i could retrofit a transmission from a different make and model. I.e the 2010 jaguar XKR makes 510hp, so could i find one of those from the salvage yard and put it on my 383.
Old May 14, 2011 | 12:29 PM
i guess you are stuck lookin for a good used hp trans. for a quality built 700 r4 that handles up to 500hp your lookin at 2k for the trans and probly around 3 hundred for the adapting. couple hundred for misc.
Old May 14, 2011 | 02:29 PM
Sorry man, but "475 hp" and "economy drivetrain" just don't go together. To get a Jaguar trans to work would require having an adapter between it and the engine. I doubt anything like that exists in the aftermarket, because frankly you'd probably one of the only ones who would want to do that. Keep your eyes open for a good used trans, I've seen some for sale from time to time. What trans do you have now, and how about the rearend too? With that engine, you need to beef up everything; trans, driveshaft, u-joints, and rearend. If any of those are left as they came stock, it will be the weak link and the first thing to break.
Old May 14, 2011 | 09:11 PM
Rose350's Avatar
could i find a salvaged trans that does work with my car and beef that up? new gears, sun shield, planetary gears, etc
Old May 14, 2011 | 09:59 PM
rebuilding a auto trans is not a easy project. requires some specialty tools. heres a couple sites with some info.
Performance Transmissions and Parts from PATC 700R4 AOD 4L80E 48RE
700R4 & 4L60E Automatic transmissions specialists - ProBuilt
Inked88
Jul 27, 2011 10:57 AM
dsinclair999
Feb 21, 2011 11:24 AM
randolphdelpriore
Jul 4, 2008 11:05 PM
DeputyDog
May 22, 2008 02:45 PM
camaro girl
Apr 8, 2007 04:58 PM
