Couple Muncie Questions
Old Apr 21, 2013 | 04:01 PM
Pfeifer30's Avatar
Default Couple Muncie Questions
Hey guys, new member here. Im looking for answers to a few simple questions. Im pretty sure I know the answers, but I would like some confirmation before I order things.
I just dropped in this crate engine
http://store.chevroletperformance.co...-19210008--%3E
Now im looking to order a new transmission. I had the muncie m20 before and Im thinking I would like to get another ( unless someone can sway me)
My question is though:
Whats the difference between bolt and stud type levers? Is it simply if the linkage connects with either a nut on the stud, or they are bolt on?
Ive been looking at this transmission: Wide ratio with 2.52
Camaro Parts | 1969-1970 | 1969-70 M20 4 SPEED WIDE RATIO TRANSMISSION WITH 2.52 1ST GEAR - BOLT TYPE LEVERS - RH SPEEDO DRIVE | Classic Industries
Or would I be better looking at the m21 and 2.20. This care will be a weekend cruiser with the occasional track day, but rarely ever. Ive always loved how the m20 shifts.
Thanks
Daniel
Old Apr 21, 2013 | 06:58 PM
mikes68's Avatar
i picked up a m-20 works great 4 me . i think just the way they attach it helps identify the year if you cant read the dates
Old Apr 22, 2013 | 05:56 AM
Everett#2390's Avatar
Stud mounting is early '60's to '68, I believe.
Bolt mounting started in '69.
First gear trans ratio goes along with rear axle ratio.
For a given axle ratio, the 2.52 will allow less clutch slippage at start and move the mass faster then the 2.20 ratio.
nickb123
Jun 8, 2011 11:15 PM
toxicat
Apr 6, 2009 01:29 AM
mtn_maro
Sep 13, 2008 09:16 PM
whammer3024
Aug 20, 2007 10:03 AM
tylersilva12
Jul 9, 2006 11:10 PM
