Anyone with OD trans and 308 rear end???
Old May 8, 2014 | 07:24 PM
Glenns-67SS's Avatar
Default Anyone with OD trans and 308 rear end???
If so what rpm's are you turning at 65 or 70 mph?? Is it a good set up or do i need to lower the gears when i swap trans--I have a set of 332's on the shelf --is that ok??
Old May 8, 2014 | 07:45 PM
With 3.08's, you're going to barely be using overdrive unless you're cruising 100 mph in the flatlands, with a tail wind. You'll be chugging the engine down at normal highway speeds, meaning you'll never use o.d. I have 4.10's, no overdrive. If I did have o.d., my gears would be perfect all around for my driving habits and performance wants. With overdrive, I would go with 3.73's which would give you great low end performance, and yet a modest highway rpm.
Old May 8, 2014 | 07:54 PM
I just realized I didn't answer your main question in the thread title. No I don't, and for good reason!!
Old May 9, 2014 | 07:28 PM
Thanks --kinda what i thought had a 700r4 and 355's in a 55 chevy and it was about right--Not racing the Camaro as it has a sag and 10 bolt--that i will replace as they die
Old May 31, 2014 | 04:54 PM
I redid the counting for the rear end numbers and paid more attention and the rear is 332 gears--dosen't help my wish for a od trans tho--2400rpm's at 65mph too with 26 in tires
camaroz803
Jul 8, 2010 08:03 PM
mrmojorisin6996
82-92 V8 Tech
Mar 6, 2009 06:28 AM
microkid
Feb 16, 2009 04:41 PM
bryans3.4 95
Dec 29, 2008 07:15 PM
jkkrs310
Aug 22, 2007 01:02 PM
