suspension heigth
Old Sep 19, 2011 | 09:55 PM
Bringheat's Avatar
Default suspension heigth
So I need a little help, I have a 1968 camaro I converted from drum to disc, had the front suspension rebuilt and now the front is way higher then stock, like 7 or 8 inches from the ground to the cross member. I did put 17" wheels on but Im not sure whats going on here. Any ideas?
Old Sep 20, 2011 | 07:53 PM
vanquishfist's Avatar
First of all welcome to the forum!
I don't think I personally can help you much because I don't have any experience working in first gens. It may be that your old springs were bad and the new brought it up. Could you show us with a picture?
You may want to ask over in the 1st gen section as this suspension forum doesn't get much traffic.
Old Oct 19, 2012 | 06:00 PM
TheTank69's Avatar
Yes, Please post a pic of this. Did you figure it out?
Old Oct 20, 2012 | 09:29 AM
77thor's Avatar
You had the front end rebuilt- did they remove the control arms and replace the bushings?
new springs? How much experience did the shop have??
Two things I can think of could cause that;
1) the springs are not sitting properly in the pocket on the control arm,
2) the bolts were tightened while the front end was 'unloaded' (off the ground) and it's causing binding.
The bolts should always be tightened when the car is on the ground and the suspension fully loaded.
Old Oct 20, 2012 | 06:57 PM
Edwardgp's Avatar
This one is only a little over a year old, I believe they are getting better.
Huss&Dalton
Jun 19, 2010 12:37 AM
MusicMan
Feb 21, 2009 11:01 AM
99camaro00
Jul 14, 2008 08:23 PM
1stgenssclone
67-69 V8 Tech
Dec 6, 2007 01:28 PM
nuttyprofessor
Oct 1, 2007 05:41 PM
