Steering Box Help
Old Jul 13, 2015 | 10:30 AM
67SuperSport's Avatar
Default Steering Box Help
Hey fellas, so I recently had my pressure line for my power steering system break on me (up by the pump, it was kind of old) so I need to change it. I want to make it into AN fittings and braided hose. Only thing is, I'm not sure what the threads on the box are. If they are metric or not because I've heard both ways. The casting number on the box is 7826692. When I took the old line off on the pressure port on the box, it was a flare with an O-Ring. I don't know what the splines are, and really don't want to take it apart if I don't have to. I'm just looking to see what fittings I need to get. Thanks for the help.
Old Aug 2, 2015 | 07:39 PM
Smee78's Avatar
Why dont you take the old line to your local auto parts store? Or to a local mach shop, they should be able to tell you the threat pitch.
Old Jul 11, 2016 | 08:37 AM
57Vette's Avatar
Just wondering if you ever resolved the issue of the thread? IIRC, early Camaros have SAE fittings, and later boxes have metric. Depends if your steering box was upgraded to a later model one like the IROC box (metric) or one of the other compatible boxes like a Mid-90's Jeep Grand Cherokee box (also metric). Pretty sure the metric sizes are 15mm 1.5 and 18mm 1.5 on the box. If the ps pump is OEM it's probably SAE also.
I picked up a '96 JGC box and will swap it with my OEM box as soon as I get the correct rag joint and adapter fittings for the two lines. I can't stand driving the car with the current no effort power steering LOL.
MIKE
93mmaro
Jul 13, 2015 09:48 AM
v8chvyguy
Nov 27, 2011 03:11 PM
racecar882
67-69 V8 Tech
Dec 24, 2010 02:32 PM
jalahma@gmail.com
Oct 30, 2008 07:43 AM
cowboy67
Aug 31, 2007 07:16 PM
