need help
Old Apr 3, 2007 | 12:32 AM
Saint27's Avatar
Default need help
I put 18in KMC rims on the front end of my 67 camaro. Now when im driving and have to make a turn the wholecar vibrates and shakes. How can i fix it?
Old Apr 3, 2007 | 02:31 AM
badinfluenceRS's Avatar
Default RE: need help
are the tires rubbing anywhere?
Old Apr 3, 2007 | 12:31 PM
Saint27's Avatar
it does when i try to turn to sharp, but thats just because of the size of the wheel. Its when I make slight turns it when it shakes. I was told by an alignment guy that my pitman arms are too long and its over working my power steering.
Old Apr 7, 2007 | 02:57 AM
jonnyNITRO's Avatar
Well, first of all, you only have one Pitman arm. It connects the steering linkage directly to the steering box.
Second, the tire not only rubs on the fender, but watch the frame inside. See if the paint is worn off behind the tires next to the firewall.
Old Apr 10, 2007 | 03:28 PM
Saint27's Avatar
Yeah its rubbed paint off the frame. How can i fix it? someone suggested shorting the pitman arm
