Lowering Suspension on '69
I am interested in lowering my '69 camaro for road handling purposes. The front end of the car iscurrently disassembled down to a bare subframe . I purchased some 2" lowering coil springs from Hotchkis. I also want to change to disc brakes up front so I have the option in some of the kits to also use 2" lowering spindles. I currently have P235/15s but can change to something different. Is a 4" drop too far for this car? If 4" is too far, how about 3"? I thought maybe I could use rubber coil spring pads under the springs (about 1" thick) and also use the lowering spindles. Any comments on disc brake kits/systems would also be of interest.
RE: Lowering Suspension on '69
I think 4 inch is a little extream. I lowered my 79 Camaro 2" and it's pretty low. My front bumper scrapes my driveway and so do the traction bars. As far as brakes. Go for the disc brakes!!!
ORIGINAL: MojoChevy I am interested in lowering my '69 camaro for road handling purposes. The front end of the car iscurrently disassembled down to a bare subframe . I purchased some 2" lowering coil springs from Hotchkis. I also want to change to disc brakes up front so I have the option in some of the kits to also use 2" lowering spindles. I currently have P235/15s but can change to something different. Is a 4" drop too far for this car? If 4" is too far, how about 3"? I thought maybe I could use rubber coil spring pads under the springs (about 1" thick) and also use the lowering spindles. Any comments on disc brake kits/systems would also be of interest. 4" is way too muc for stock suspension geometry. also anything more than 2" could run you into shock travel troubles. coil spring pads to lower? don't understand that new dropped spindles are gonna cost you a pretty penny. usually if you buy them from someone (Fat Man is real good), they will have a spring and caliper kit. my suggestion is to go with the springs and see how you like that. engine weight, A/C, and other front end stuff will allhave a significant affect on the final drop. sometimes if you lower the front end you will have a hard time getting an alignment out of it and you might need to buy offset upper A-Arm shafts you will (should) also have to drop the rear. you can do this with a de-arched spring or a 1" lowering block (most I would recommend). you can either buy a front bakes disc kit(around $800.00) for the car or search out a 68-72 nova in the junkyard and try to find the set-up there. either way you will need a new proportioning valve and if you are changing from stock drum I'm sure a new master and booster is in order. (I actually have a booster I could sell you that's in pretty nice shape). one often IMPORTANT overlooked thing is after you go to disc brakes, you need to change the rod position going to your brake pedal. (if you are going to power, this will need to be replaced also good luck at whichever way yo ugo |
The drop spindles are a great choice. This maintains your shock height and feel. 1969SS is right about the disc brakes, try a junk yard first. 1969 Camaros did have optional disc brakes. Maybe you can find some. The conversion kits are expensive!
I actually swapped out from entire subframe for a '71 with disc brakes. I am going with 2"drop spindles and low profile tires. Won't know exactlly how it's going to look until I get the wheels and tires though. NEVER! I repeat NEVER heat your springs to lower you car. You can cut them (with a torch), but never heat them. Just a warning to others. The rubber sprng spacer would help to bring it up an inch but I think everyone will agree that 4 inches is too much. Start with the spindles. If you want more, then swap out the springs. Don't go too far too fast. I did that once on my 65 El Camino and dragged the frame down the street as the springs settled in. Remember that they will have to settle once reasembled. |
Johnny I wanna add to her post please do not cut the springs either.
I know. Spindles are the best way to go.
I have drop spindles with adj. coils all the way around so that is a easy way of lowering ur car.
How do you like those adjustable shocks?
no shocks all coilovers
Do you have a picture? And some instructions about how their adjusted? I've never used those.
| All times are GMT -5. The time now is 06:02 AM. |
