HELP! 1968 Camaro front end height
Old May 14, 2024 | 01:09 PM
Roger68's Avatar
Question HELP! 1968 Camaro front end height
1968 camaro 327 all new front end, springs are original and a 2 inch drop spindle it dosent look right to us any suggestions on how to get it lower?
tia
Old May 25, 2024 | 01:05 PM
bruce69camaro's Avatar
I don't have a 68 but on my 69, I have a 496, I added 2" drop spindles and like you, I didn't like how it looked, so I cut the front coil springs.
My suggestion is, if your springs are good, then reuse them but if they are old, buy new ones. Don't go crazy by cutting off a full link, cut a 1/4 of a link at a time. Let the car sit because it will settle down a little. I also bounced the car to make sure the coil ends are in the A arm notch correctly. By the time I was done, I cut 1-1/2 coil off.
Old Jun 2, 2024 | 11:10 AM
Chris7117's Avatar
Why not look into coil-overs? I added QA1 coil-overs to my 68 and can adjust the height easily. I do not know how to calculate the drop spindles into the equation but calling QA1 might give you insight. I have old tired drooping leaf springs in the rear so I have work to do to get the rear correct.
Good Luck, it seems stance is an art, not a science.
ChevyGuyToo
Jul 22, 2023 02:06 PM
donmcgowen
Sep 5, 2019 10:58 PM
Tommy68
Mar 17, 2019 10:50 PM
Camaro1968
Dec 4, 2016 11:22 AM
chevydog
Feb 28, 2008 12:54 AM
