Camaro/Nova Coil Springs
Old Apr 7, 2007 | 04:51 PM
pistolpete_67's Avatar
Default Camaro/Nova Coil Springs
Alright, I have a 67 Camaro and had to put a new subframe on the front of it, well the shop I took it to found/had a cheap 1970 Nova Subframe that he put on and it worked out well, but now the front end sits up a little higher than it did before. My questions is are the front coil springs from the 67-69 Camaro and the 68-74 Nova the same height? From the looks of it, it seems like the Nova sits up a little higher, but I can't find any specs in writing that will tell me the stock height of the two. Any help would be great. Thanks.
Old Apr 7, 2007 | 05:54 PM
Blade's Avatar
June 2007 ROTM
Default RE: Camaro/Nova Coil Springs
Not sure on ur answer. What motoru have? The shop may have put bb springs on the car and if u have a sb then it wont weight it down that much.
Old Apr 7, 2007 | 05:56 PM
74454bb's Avatar
May 2007 ROTM
Find out if the nova had AC, they are heavier springs on the AC cars.
Old Apr 11, 2007 | 11:18 PM
jonnyNITRO's Avatar
I thought the Novas ran struts up front?
Old Apr 17, 2007 | 02:48 PM
1969 SS's Avatar
there are a bunch of possible variables. big-block, small-block, six cylinder,A/C car, non-A/C car or any combo of two not to mention the possibility of an aftermarket spring.
there is no way of telling. it might even be that your springs were just junk and sat lower and you were even losing performance from them. your best bet is to put new springs in. when you did the swap you should have replaced everything before putting it in anyway. safer and much easier than doing it now
camarolife97
May 7, 2015 12:02 PM
mainejohn
Mar 18, 2011 07:05 PM
rbarker69
67-69 V8 Tech
Jan 21, 2011 10:31 AM
BasicConcepts
Sep 14, 2010 04:52 PM
Eric89RS
Apr 29, 2007 07:36 PM
