my 69 camaro project
Old 05-21-2010 | 04:17 PM
orocker's Avatar
December 2011 ROTM
Santas Little Helper
Originally Posted by Hambone
I really have to ask..What did all that body work and parts cost in the end? Would it have been cheaper to buy a newly production body?
The restoration and paint job cost me about $9k. The body guy I used was old school and used leadfill and shaped it with wood tools. Paint job....well let's just say it's bubbling in places and he's out of biz now so I'm stuck with it. It will do till I decide to repaint it down the road a few years.
So far in parts we have spent close to $22k. Yes it's all been worth it. Funny thing, when I got into this I had the chance to buy a mint condition numbers matching black w/white interior 69 vert for $36k. Guy at the dealership told me it would gain value over time and that it would be like a collectable. I laughed and said I don't want to own it to look at it but to drive it. I never thought I would have as much into as I do. A friend convinced me to restore it and that I could do it for 18-20k. Lol
I know what was done to mine and how it was put together. My husband & I have done everything else to it so far and it's been a great project. I will be very proud driving down the road in it when it's done.
  #312
Old 05-28-2010 | 09:39 AM
Hambone's Avatar
On a side note, how does one get the chrome molding around the windows off?? Is there some trick?
  #313
Old 05-29-2010 | 11:12 PM
Squid's Avatar
very carefully....use a wide bladed flathead screw driver to pry them up to pop them off of their retaining clips. Use a towel between the screw driver and the paint to keep from screwing up your paint.
  #314
Old 05-30-2010 | 09:46 AM
Hambone's Avatar
Thank you!!1Paint is not an issue on mine yet..lol
  #315
Old 06-20-2010 | 06:46 PM
jamesfreddys's Avatar
Wow, you have come a long way. Your making me tired with all that hard work.
  #316
Old 07-07-2010 | 07:35 PM
CamaroBeau's Avatar
Default RE: Good Luck!!!!
I am so happy of the developments of your project. Keep going and hope to see more in the coming days...
  #317
Old 07-09-2010 | 11:13 AM
CamaroBeau's Avatar
Hows the project going on? its nice to see how are things going on from that camaro. I am so glad you found someone to help you. Good luck.
  #318
Old 07-19-2010 | 09:45 PM
orocker's Avatar
December 2011 ROTM
So time for an update. Sorry its taken so long. I used my iPhone to take video of the Squid cutting and welding the AC bracket but the iMovie app only lets you combine the videos into one long video but not edit them down at all. So I just decided to combine them together and use the reg video cam next time. lol.
What we did was cut and weld the AC bracket. We are using an aftermarket AC unit that my body guy got for me. He said he used them before and it was rather inexpensive so we went with it. So far so good till we got to the bracket that holds the compressor on. The bracket does not line up with the water pump and manifold at the same time. And with the type of bracket I have for the Alternator, that needs to sit on the left front of the motor and we decided that the AC compressor needs to sit on the right front. As you can see by the 1st pic that it needed to be cut down and welded allot....which is where the Squid comes in and saves the day with his new welder.
So here's the video of the Squid cutting and welding the bracket.
So here's the finished product. You can see that after it was welded he drilled 2 holes in the one long side and welded on some washers.
And here's the new bracket holding the compressor in place.
  #319
Old 07-19-2010 | 09:49 PM
Stix80's Avatar
sweet looks good did you get the belts all attached
  #320
Old 07-19-2010 | 09:51 PM
orocker's Avatar
December 2011 ROTM
No, the next thing we have to do is cut some holes in the firewall for the AC hoses and make a bracket that will hold all the AC and heater hoses off to the side of the motor. I dont have any of the belts I need yet.
Quick Reply: my 69 camaro project
