My 67 RS/SS wake up
Old Jul 8, 2018 | 07:57 PM
  #21
Finished up the brakes so all the seals in the system are new. Got the new tires/rims on. I am going to syphon out the old car and put in some fresh. Then I can get out in the driveway and wash it.
I found some other issues, Its going to need a new drivers side mirror it will not hold adjustment something is going on with the shifter, it seems to have a lot of play in it. I also found several paint chips I would like to touchup. 5 year storage was hard on it with a now 9 year old boy in the house.
Old Jul 8, 2018 | 10:16 PM
  #22
Al Loyrat's Avatar
I replaced my drivers mirror in 1988 with a factory mirror. A couple years ago the mirror head got loose. I took it off and soaked the mirror head in lacquer thinner and that allowed me to pry the mirror glass off. The ball/socket is held taught with rivets or screws. Mine has rivets so I took a small peen hammer and peened the play out of it. Cleaned off the silicone residue and applied fresh black silicone, pushed the mirror glass back on. Still holding up!
Old Jul 9, 2018 | 11:07 AM
  #23
I am not sure if the mirror is original or not but I think I am going to put it with all the other original parts and just buy a replacement from Ricks. Is like $37 and I am going to try to get an order of $250 so I can save 25%
I got to rinse it off today. It still needs a ton of cleaning. I like the 15s on there. I drove it. I believe the accelerator pump is not working. She idles nice but fall flat when I hit the petal.
Can you tell I am a Camaro fan boy
Old Jul 9, 2018 | 09:26 PM
  #24
Al Loyrat's Avatar
"Can you tell I am a Camaro fan boy" Yes, and the red one is my favorite
Old Jul 9, 2018 | 09:42 PM
  #25
I like my 4th gens but I wish it was a 1974 350-4 speed sitting next to the 67. Although It would take a little work to get as fast, and a ton of work to get to go around a corner and stop like a 4th gen.
Old Jul 10, 2018 | 04:29 PM
  #26
People are looking for 1st gens hard. I had the car in the drive way for about 5 hours on Sunday and I live on a very low volume traffic road. Today I had the garage door open and two people stopped to see if it might be going up for sale. Neither where my close neighbors. I guess word got out.
I removed all the hoses and the thermostat. Coolant and rad look good but there was a lot of buildup in the thermostat housing of a hard white/gray material. It must be coolant breaking down.
I have all new hoses and I plan on doing a water pump but I think I am going to flush it first.
Old Jul 10, 2018 | 09:35 PM
  #27
Al Loyrat's Avatar
Didn't check the voltage in the old coolant?
Old Jul 11, 2018 | 06:22 AM
  #28
The coolant was 7 years old the hoses were 20 years old. When I started it was just maintenance.
Old Jul 13, 2018 | 03:26 PM
  #29
Parts is parts. I did not buy the mirror from Rick's. I found the same part number on EBay. I also found the Hotchkis X brace on ebay and my wife had a 15% off ebay purchase coupon. I have never seen the X brace less then $177, I got it for $151 and the mirror was under $24.
I found the heater core will not hold pressure so that will need replaced. Add that to the list.
Old Jul 15, 2018 | 07:24 PM
  #30
Ordered a new heater core from Rock Auto, not here yet, Flushed the coolant system, going to let the flush sit in there until the heater core gets here.
I tried to install the X brace and found 3 of the 6 internal frame nuts missing. I ordered some nutserts, I am not sure I can make them work but its worth a try before I get out the death wheel and welder.
I have moved over to the Carb, The accelerator pump is not working at all, I got it apart and I was expecting more varnish. It seem pretty clean. I am not sure what is going on. I do not see and holes in the pump diaphragm.
