68 Project Dementia
Old Mar 6, 2012 | 07:44 PM
Chevynutz's Avatar
Default 68 Project Dementia
The 68 before tear down . Hope i can remember where all the part's go back !!!
Old Mar 6, 2012 | 08:30 PM
Chevynutz's Avatar
First day of tear down .
Old Mar 6, 2012 | 08:34 PM
Chevynutz's Avatar
Front end removed !
Old Mar 6, 2012 | 08:51 PM
Chevynutz's Avatar
Sub frame painted along with firewall. Prior to removing the sub frame i degreased and pressure washed underneath twice. 40+ year old bolt removal can be a chore.
Old Mar 7, 2012 | 09:44 PM
Chevynutz's Avatar
Sub frame mounted with new bushing's. Upper and lower A arms blasted and painted with new bushings. New upper and lower ball joints and inner and outer tie rod ends. Sprayed bottom with undercoating while everything is removed. I have one patch of rust repair to do on the driver side lower cowl panel. I feel very fortunate compared to some of the Resto's i see on here. Now i have to order a front Disc conversion kit. I'm leaning toward's Matt's classic bowtie's kit. More photos soon i hope !!
Old Mar 18, 2012 | 06:52 PM
Odin's Avatar
Nice project. Good luck with it.
K
Old Mar 18, 2012 | 10:46 PM
Chevynutz's Avatar
Default Project
K
Thanks, finally somebody replied after 140 view's !!!!
Old Mar 19, 2012 | 06:24 AM
Odin's Avatar
You've got a lot to work with. My 69 restoration needs lots but I'm hoping to have it done before Easter. (Body and paint only.)
K
Old Mar 31, 2012 | 10:52 AM
dazed n confused's Avatar
Did you blast the frame and firewall? It looks great!
Old Apr 1, 2012 | 06:36 AM
Odin's Avatar
Yes I did. I should have some updated photo on my thread.
K
