67 Restoration - Shark Bait (NH)
Old Mar 24, 2013 | 08:35 AM
Shark Bait's Avatar
Default 67 Restoration - Shark Bait (NH)
Well my son and I thought we were buying a #'s match 67 last year but when it was delivered it was quickly obvious it wasn't. Good news is we kept the car and nocked the price down by $5K. Because it wasn't a #'s match we went crazy and painted it hugger orange with black bumble bee, yeah I know it wasn't available in this color scheme in 67. Here are some before/after and progress pics. The engine turned out to be a pretty good gem, 350, 4-bolt main, pulling 175 psi (+/-) 5% in all cylinders and less than 10% leak down. We still pulled it apart and gave it a new set of bearings and seals. Hopefully in the next couple weeks we'll be dropping the engine in. Pricetag so far including shipping $15K
Old Mar 24, 2013 | 09:42 AM
77thor's Avatar
Nice Job.
Love the kiddy pool 'drip pan'.
Old Mar 24, 2013 | 10:31 AM
slick's camaro's Avatar
Paint looks good. You painted it yourself?
Old Mar 24, 2013 | 10:51 AM
Everett#2390's Avatar
Looks nice. Love the sleeper look of painting the alum manifold Chevy orange.
Old Mar 24, 2013 | 11:08 AM
Shark Bait's Avatar
Hey, thanks, no we did the strip and prime and undercoat, I had a pro take over for the final coats of paint. We've been doing all the other work .. it's been a good learning process. Every bolt/screw/nut/wire was removed from the car.
Most of the big ticket items we replaced:
Master hardware kit.
New Quarters, the ones on it were done at one point in the 70's I'm guessing because they were brazed on.
Drivers side floor had a punch hole in it, looked like he ran over a stone wall so we replaced that.
Four new wiring kits from AAW, (Main Upgrade Kit/+Convertible/+Headlights/+RS)
Header Bow on Convertible
Complete deluxe interior with dash pad
Convertible top
Gasket kit (doors/trunk/convertible/....)
Axle Tube from a 72 Nova (old one had been cut & c-clip eliminators installed)
Full disk brake kit
Tubular A-Arms
Stearing links redone (ball joints)
Felpro Engine Gasket set
Pertronix Distributor
The nose was in pretty good shape. Just had to do a little adjusting to the headlight doors and buy some bushings/teflon washers and limit switches.
Old Mar 25, 2013 | 05:55 AM
Still looks nice.
I bet the logbook is getting thick.
Staying with externally reg'd alt or going internally reg'd?
If staying with ext reg'd, I suggest getting an electronic VR, Wells P/N VR715, transfer the cover to look like OE, and add a 63 amp 10DN alt.
RockAuto sells both.
Old Mar 25, 2013 | 06:55 AM
Shark Bait's Avatar
Still looks nice.
Going internally regulated. The kit I got from AAW was an upgrade and didn't have the hookups for the VR/Horn Relays and a few other of the older setups. Because it's not all original I just figured on going with an internal regulated alt.
Old Mar 25, 2013 | 09:34 AM
So AAW wired the new harness for an internal reg'd alt, cool!
Old Apr 10, 2013 | 03:42 PM
Shark Bait's Avatar
So my kid came home from his Airforce base this weekend and we banged out the engine install and the convertible top install. Sorry I was so nervous during both that I only got after photos and not during.
Old Apr 16, 2013 | 07:02 AM
Smee78's Avatar
Looks like your project is moving right along, congrats on your son choosing the AF.
