1967 camaro RS restoration
Old Mar 7, 2013 | 06:05 PM
mags67's Avatar
Default 1967 camaro RS restoration
Hey guys I just got my camaro a couple months ago. I got it as a rolling chassis and I now have it torn down to the shell by itself off the frame. I am getting the frame powdercoated and then I am going to reinstall. I was wonder what the process is going to be to get the car completed. Is there any specific time I should take into paint? Is there anything else important to do to the car while I still have it at this stage?
....I pretty much just don't know where to start once I get this frame back on and get it to a rolling state again.
PLEASE help me guys.
Old Mar 24, 2013 | 03:39 PM
Shark Bait's Avatar
Take it to paint now don't wait for the frame to come back. Most Painters I know are going to want it all apart not assembled. They can get started with the body and panels and then when the subframe comes back you bring it to them with all the body hardware and they'll do the assembly as they prep/prime/shoot.
Old Jun 19, 2013 | 06:00 PM
Ron Long's Avatar
agreed, paint it now, that way you can take care of the under coating, the firewall and the inside without having to tape anything off.
Old Jan 20, 2014 | 09:19 PM
iamivan's Avatar
Depending on how much you know of the body condition, I would consider having it blasted or chem cleaned, or some (new method I'm sure is on the market) to really get a good understanding of the metal in all areas (under the front window - behind the dash, etc...) I would get those areas blasted (sorry sand or bead blasted) really well so you can ensure the metal isn't punky. Also look at the obvious - floor pan, rockers (underneath) and fender wells. Now's the time to check that stuff out and you'll not have another opportunity like this for less money than what your spending already.
Old Feb 7, 2014 | 11:25 AM
Mark212's Avatar
I wish I could powder coat mine. Cost prevents this but someone must have put 20 coats of krylon in my engine bay over the years. I am striping as much as posible then getting Eastwood firewall paint to have resprayed.
Old Feb 8, 2014 | 07:24 PM
Did you check the fit of everything before you tore it down? Once you paint the car you will be very limited on how you can adjust body lines and body gaps.
CamaroDad
Oct 16, 2010 05:42 PM
67Harbor
Apr 5, 2010 01:21 PM
pwave
Apr 1, 2008 11:45 AM
dewees327
Jun 30, 2006 12:59 AM
