Throttle positioner
Old May 2, 2023 | 02:22 PM
rsilva_67's Avatar
Default Throttle positioner
I have a new (to me ) 67 Camaro. It has a Holley carb on it. There is a piece mounted to the carb throttle with it's own cable separate from the throttle. it has 2 wires connected to it. It seems likle it may be a thrpottle positioner but I don't know why it's there. Tried to follow the wires with no luck. Any ideas would be appreciated.
Old May 2, 2023 | 06:26 PM
It has two cables and two wires?
Maybe you could post a picture?
What does the cable do? Does it have a manual choke or electric or vacuum? Could it be a kickdown for an automatic transmission ?
Does it look something like this?
Old May 2, 2023 | 09:28 PM
rsilva_67's Avatar
Default Yes
Looks a lot like that. 2 wires on it and a braided cable connected to the carb throttle bracket
Old May 2, 2023 | 09:33 PM
rsilva_67's Avatar
Default Kick down for trany
It has electric choke on the other side of the carb. Trans will not down shift when I punch it. Have to manually down shift
Old May 3, 2023 | 05:40 AM
Post up a picture so we can have a look,what motor and trans does it have?
Sounds like it's not stock to the car possibly?
Old May 3, 2023 | 01:07 PM
rsilva_67's Avatar
Default pic
her you go--thanks in advance for any help
Old May 3, 2023 | 01:38 PM
rsilva_67's Avatar
Oh Forgot 327 with a TH400
Old May 3, 2023 | 07:33 PM
I thought maybe it was a T400,they have an electric kickdown switch.
That is what you have with the short cable going to it and the two wires attached.
It could be that switch is bad or the switch on the side of the trans,it's a little plug with one wire or the kickdown solenoid itself inside the trans pan.
Old May 3, 2023 | 07:47 PM
This switch is on the side of the trans.
This solenoid is in the bottom pan.
Old May 3, 2023 | 07:55 PM
rsilva_67's Avatar
Ahh-- thank you very much. I truey appreciate your help.
