what's normal rpms?
Old 05-30-2013, 07:15 AM
dallas612's Avatar
Um I dont know exactly but the coil is on the firewall. Its round and is incased in a chrome msd holder. Its red inside and it jumps to the distributor. I connected the green wire to the negative on it.
Old 05-30-2013, 07:38 AM
Ok, I had some suspicions about the ignition, which is why I asked, let's see if luck continues. Look around, either in the engine compartment, stuffed under the dash inside the car, etc. for a red ignition box (about the size of a brick) that says MSD on top of it. If a previous owner added that, then you do NOT hook the tach up to the coil, there will be a tach output on the MDS box.
Old 05-30-2013, 10:07 AM
dallas612's Avatar
Yeah I know what they look like but I haven't seen one but I also haven't looked either. I will go look now lol.
Old 05-31-2013, 03:32 AM
dallas612's Avatar
I can't find a box anywhere
Old 05-31-2013, 10:12 AM
Do you have, or know someone who has a spare tach laying around that you could try?
That way you can rule out, or in, your tach being defective.
Old 05-31-2013, 06:33 PM
dallas612's Avatar
I have come to the conclusion that this engine simply doesnt rev anywhere near as high as my stroker. I have been comparing apples to oranges. This tac is probably right, it is I that was expecting more I guess.
Old 06-01-2013, 01:10 AM
Originally Posted by dallas612
I just installed a tach in the 68. Older 350 engine (nothing special) th400 and a 8.2 rear that I'm unsure of the gears but I'm bettine there 3.42 or lower. The tach says the car idles around 700-800 and if I mash the gas during driving I didn't see it go over 3k even though it sounds like it can't go higher lol. Normal crusing at 50 mph is around 1.5k.
Oh man, even if your engine had a couple of cylinders that weren't firing, you'd be able to rev it beyond 3 grand. And only 1500 rpm at 50 mph? No, something's not right. But it's tough to say what, with my ears out of range.
Old 06-01-2013, 07:23 AM
Everett#2390's Avatar
Check distributor brand. If electronic, go to the manf's site and read installation instructions as they would give tach output lead.
If MSD, you might need a tach adapter.
If OE point dist, tach is faulty. Sun tachs have worked very well on point set dist engines since the early '60's. Super Sun tach worked on a '98 Honda DX I had, but the Honda ign system had a tach lead and the tach indicated correctly, or, at least sounded like engine rpm and tach matched.
I agree, your engine reads like it runs very well.
Old 06-01-2013, 10:51 AM
dallas612's Avatar
The engine does run great, not as powerful as I would like but smooth for an old 350. My neighbor who has a 600 hp nova that he drags told me that its right for this engine and not to compare it to my stroker. See, my first engine I ever dropped into a car was my stroker and its all I have ever known when it comes to old cars. Oh well, ill know for sure when I relocate the stroker in place of the 350 lol
  #20
Old 06-01-2013, 02:40 PM
Again....
...if I mash the gas during driving I didn't see it go over 3k even though it sounds like it can't go higher lol.
This is NOT right for your engine, or any other engine for that matter.
A stroker engine, is not a higher winding engine than a 350 is, unless you have the rotating assembly balanced.
Your neighbor is smokin some wacky tobaccy if he thinks that your engine topping out at 3k is "right".
Quick Reply: what's normal rpms?
