Trouble removing back seat on 68 Camaro
Hi Everyone,
I'm a newbie and I recently became the proud owner of a 68 Camaro Coupe. There are no rear seat belts and the guy I bought it from says he doesn't remember if they were taken our or just shoved underneath when he had the seats re-upholstered replaced several years back (he had this car 34 yrs). I searched on the forum and saw that I should be able to just push down on the front of the passenger and driver side to un-hook it from the latch and it would then slide out. I tried that and didn't work. I looked underneath the rear seat and saw where the latch meets the wiring harness and it's in there pretty tight.
Can anyone recommend how I can get that unlatched? I plan to replace the upholstery so I don't mind doing some damage to it if needed.
Thx.
Thx.
You need to push back hard on the seat frame (not down), then lift up when the bar on the seat frame clears the hook "latch". You'll feel the metal frame near where it meets the floor. The seat can be stubborn to release, and you may need to coax it back with a whack from your knee. The seat is latched on both sides.
miguelg510
06-11-2008 09:46 PM
