trim tag question
new member with what may be a simple question...my car is a 549xxx vin and has the larger Norwood trim tag....looks like all numbers are there except the exterior trim code..there are no numbers at all below the pnt code....has someone messed with this or did it happen at times ??? thank you for reading ..I have found the answer
dizzee03
Sep 22, 2011 01:29 AM
