Transmission Line Flare Nut Fix
Old May 4, 2008 | 10:11 PM
RS383's Avatar
Default Transmission Line Flare Nut Fix
Replaced the radiator on my 68 Camaro this weekend and I rounded off the flare nut on the transmission line. Looking at replacing it, can the nut be replaced? I haven't worked much with these types of lines. (yes, I was using a flare nut wrench, but the guy who worked on it last had beat the heck out of the nut and it wasn't savable). If I replace the line itself, it looks like the passenger side header has to come off for sure, maybe lower the transmission as well. That seems like too much work for a simple problem. Any suggestions? Is there any alternative to replacing the line? Can I splice in a new end and nut?
Thanks
Old May 4, 2008 | 10:58 PM
74454bb's Avatar
May 2007 ROTM
Default RE: Transmission Line Flare Nut Fix
I spliced one before with a rubber hose, just make sure it's trans fluid safe....and I wouldn't keep it like that long.
Old May 5, 2008 | 06:36 PM
Blade's Avatar
June 2007 ROTM
Have u thought about running new lines?
manslaughter299
Jul 24, 2012 03:17 AM
Backinblack
Jun 19, 2011 09:27 PM
dsinclair999
Feb 21, 2011 11:24 AM
Ryanizzle
Dec 14, 2008 11:37 AM
