Transmission HELP?!
Transmission HELP?!
I want to replace the TH350 I have right now with a 4-speed autofordecently lowRPMhighway cruising... I was all set on getting a 700R because of it's sick 1st gear and decent OD until I found out that without major torque it will bog 2nd and requires too much modification to install...[:'(]
So I was reccomended to look into a 200R. I was told that the 1st gear is no where near as aggressive as the 700, but that the OD is better and install is simple. So my questions are, is all of this accurate? Besides the complete tranny, what other hardware do I need for the install and where is the best place to get it all? I also have a B&M shift kit in the car, so what will I need to make that compatible with the new 4-speed...?
Thanks in advance!
Thanks in advance!
dsinclair999
02-21-2011 11:24 AM
