Tire Clearance
Old Sep 30, 2009 | 03:19 PM
ChefJammy's Avatar
Default Tire Clearance
I've been looking through the forum and i have seen threads about tire sizes but most of them have been involving tires on 17 inch or bigger rims. What i need to know is if i put a 15 inch rim on the back of my '69 what would be the biggest tire that i can fit without worrying too much about rubbing against the wheel wells. Right now i have 14" on the car and wanted to go bigger in the back.
Old Sep 30, 2009 | 05:58 PM
68Elmo's Avatar
I've seen many members including myself put 275/60/15s in the back. That's prob as tall and wide as you'll go before you hit something. The backspacing is key because you don't want the tires to stick outside of the fender well, but also don't want the tires to hit the bottom shock tower.
Old Sep 30, 2009 | 08:10 PM
ChefJammy's Avatar
So if i go with an original style 15x8 and put that size tire on there i should be straight?
Old Oct 1, 2009 | 11:03 AM
68Elmo's Avatar
I'm not certain what the factory offset is on the 15x8 rally's. I know the 60 series would fit but I'm not sure how wide you can go. I think it works but not 100%. Go to camaros.net and search 275/60/15 and see results.
Old Oct 15, 2009 | 07:04 PM
jim fowler's Avatar
i run 255/60/15 that makes them about 9 1/2 inch
Old Oct 15, 2009 | 08:17 PM
1969 SS's Avatar
an original Corvette 15x8 should allow you a 255/60/15 without rubbing, at stock height, without any added weight in the rear.
to be safe, it wouldn't be a bad idea to grind your quarterpanel lips back to just before the spotwelds though (DO NOT GO FURTHER!!!!). this way if you put someone or something in the rear, you still won't rub
Old Oct 16, 2009 | 05:52 PM
jim fowler's Avatar
trust me i run 15x8 corvette wheels it works the fourlink hard no rub
Old Oct 19, 2009 | 09:18 PM
dj69z28's Avatar
My 255/60R15 size tires on back and 235/60R15 on front all riding on 15x7 GM wheels ride fine and never rub. Stock suspension/ ride height.
Old Oct 19, 2009 | 09:22 PM
dj69z28's Avatar
I run 255/60R15 on back and 235/60R15 on front using stock 15x7 GM wheels with stock suspension and ride height. They ride fine and never rub.
Old Nov 3, 2009 | 08:01 PM
Popkorn69's Avatar
I am running 275 60 r 15 with no issues ... I did add a slight lift to the rear .. but it was not needed for the tires
