sun super tack question
Old Mar 30, 2012 | 07:34 PM
camarodawg's Avatar
Default sun super tack question
how do you wire it to a HEI distributor?
i see 3 wires on the back one says ignition, where does that go?
one says trigger, does that go to the distributor cap marked TACK?
and the last says ground, i think i know where it goes
thanks
Old Apr 2, 2012 | 11:09 AM
bruce69camaro's Avatar
You should have four wires, red, white, black, green.
Red- to 12v source when key is turned on.
White- to light/ gauge panel circuit on fuseblock.
Green- to TACH on distributor cap, probably need a female wire terminal.
Black- ground.
Old Apr 2, 2012 | 11:48 AM
MKCoconuts's Avatar
Unless he didn't get a illuminated one, which is very rare now since pretty much that's the standard with gauges. But if that'd be the case, then he'd have three. What colors are they?
Old Apr 3, 2012 | 06:56 AM
camarodawg's Avatar
thanks guys for your help
Shark Bait
Mar 24, 2013 08:55 AM
Jimmyvegas
Jan 28, 2012 10:14 AM
Domobomb
Apr 19, 2009 04:30 AM
adam lutz
Jan 24, 2006 12:09 AM
