Subframe connectors
Old Jan 29, 2020 | 05:36 PM
Bob Howeth's Avatar
Default Subframe connectors
Recently purchased a 67 Convertible that will need a complete new body. Looking for suggestions on subframe connectors for a convertible. Welding in is not an issue. Not putting in a big block. Looking for some input on subframe connectors and if you can get rid of “cocktail shakers” if you add subframe connectors
Old Jan 29, 2020 | 05:51 PM
SoCal67's Avatar
IDK if you can eliminate the cocktail shakers if you have sub frame connectors but they are always a good idea for a Vert or Coupe
I just installed the Summit brand ones to my otherwise stock rear leaf set up (bolt in). If you are going with a aftermarket suspension like RideTech, Hotchkis or DSE than get theirs as the "fit" is likely better to bolt to their stuff
Old Jan 29, 2020 | 06:13 PM
Everett#2390's Avatar
SRD has a nice set, if still in business.
The shakers were installed for deleting/absorbing body harmonics from going over the road surface, i.e., railroad tracks, etc.
Old Jan 30, 2020 | 12:08 PM
Hotchkis makes a stiffening kit that include frame connectors and a more exhaust friendly cross brace. If you are looking for the rigidity of a coupe you are going to need to look at roll bar type structures that ties into the fire wall.
https://www.jegs.com/i/Hotchkis/515/...SABEgKmpPD_BwE
thefley
Dec 9, 2011 02:43 PM
SHOoffSS
LS Series Tech
May 20, 2009 01:54 AM
84 Z28 Bowtie
Mar 25, 2009 06:27 PM
nabisco
82-92 V8 Tech
Aug 25, 2008 07:58 PM
clp2112
May 27, 2008 07:08 PM
