Standard and RS Fenders????
Old Oct 13, 2007 | 03:58 PM
BlackAce's Avatar
Default Standard and RS Fenders????
What is the difference betweeen Standard fenders and RS Fenders?
Old Oct 13, 2007 | 11:01 PM
tommynos's Avatar
July 2007 ROTM
Default RE: Standard and RS Fenders????
ORIGINAL: BlackAce
emblems?its cheaper to replace just the emblems instead of the fender and emblems...just playing....there is no difference?
Old Oct 14, 2007 | 11:14 AM
BlackAce's Avatar
Then why do vendors offer fenders for standard and RS?
Old Oct 14, 2007 | 03:48 PM
tommynos's Avatar
July 2007 ROTM
hmm?,maybe for the hole placement for the rallysport emblem....maybe you do have to get a certain fender so you dont have to fill the hole,not sure ...
Old Oct 14, 2007 | 06:16 PM
wildpaws's Avatar
You'll have to ask the vendors. The only difference I'm aware of is emblem placement, the shape and size were identical. The only body panel I'm aware of that was different on the RS was the piece under the rear bumper which had holes for backup lights, everything else was identical in shape/size, only some trim/emblem holes were different.
Clyde
Old Oct 14, 2007 | 07:52 PM
Blade's Avatar
June 2007 ROTM
rs is for hide away head lights
Old Oct 15, 2007 | 10:11 AM
BlackAce's Avatar
So the difference is just the head light buckets?
Old Oct 15, 2007 | 10:28 AM
tommynos's Avatar
July 2007 ROTM
"emblems"no buckets no nothing,just emblem mounting holes...call a vendor..
Old Oct 17, 2007 | 03:22 PM
New here, but not new to Camaros. The RS front fenders have brackets on the inside edge where it butts up to the grill on either side. The bracket is what the headlight door assembly bolts to, which the standard model doesn't have. You can also buy just the brackets to attach to a conventional fender to mount the RS headlight assembly. A conventional grill won't fit between a pair of RS fenders unless the brackets are removed or bent back out of the way. RS inner fenders are also different, they have a hole to clear the bellcrank for the headlight doors.
Old Oct 20, 2007 | 12:11 PM
BlackAce's Avatar
I emailed Firewheel Classics and this is what hey said. Similar to Camaro 69
They have different headlamp housing mounting brackets.The only fenders that are not different between rs and standard are the 69 fenders.[/align] [/align] Thanks,[/align] [/align] Patti Stinson[/align] Firewheel Classics[/align]
