Smog tubes removal help
Old Jan 29, 2008 | 06:29 PM
Ejam's Avatar
Default Smog tubes removal help
I am trying to remove the smog tubes from the manifolds. So far I have soaked them with PB but it didn't do it. I have not tried to heat them yet. Any suggestions?
Old Jan 29, 2008 | 07:10 PM
sweet1967camaro's Avatar
Default RE: Smog tubes removal help
At the machine shop I work at we heat around the plugs, then put wax on the plug so it melts around it. We've always got tricky plugs, bolts and everything else off that way.
Old Jan 29, 2008 | 07:17 PM
wildpaws's Avatar
Good tip, I'll have to remember that one!
Clyde
Old Jan 30, 2008 | 10:51 AM
1969 SS's Avatar
ORIGINAL: sweet1967camaro
that's one I always forget about, until after I have 2 or 3 smashed knuckles
Old Jan 30, 2008 | 11:52 AM
Ejam's Avatar
what kind of wax? regular car wax?
Old Jan 30, 2008 | 05:49 PM
Normally I just cut off the pipe and put a 6 point socket on on the fitting. If it still fightsmeI heat the fitting cherry red so it expanes inside the manifold breaks the rust bond, then let it cool down and turn it right out.
Old Jan 30, 2008 | 06:28 PM
We use a block of wax thats seems to be the same thing as regular candle wax. Go to Walmart and get a candle. That way youll get that bolt loose and have the garage smellinggreat too.
Old Jan 31, 2008 | 12:18 AM
Ejam's Avatar
Gorn I am trying to save the smog tubes cause they are original and in great shape.
Old Jan 31, 2008 | 05:41 PM
I wish you luck, They tend to rust from inside out. They could be good, they could also twist off as soon as you get the fitting to move.
lightningcruiser
Feb 28, 2013 10:40 AM
Goose6
Jul 30, 2011 04:53 PM
Goose6
Jun 27, 2011 08:44 PM
BlueKitsune
Dec 16, 2008 12:11 PM
SSPOWER
Oct 9, 2007 01:05 AM
