Rubbing Front Tires
After driving my car around, I've found that I have a small issue. My tires rub when I hit the slightest bump. My modification to the car is definitely part of the issue. First, I'm running 8x15's in the front. Second, I cut off part of the springs to lower the front a bit. The reason I did this is because I like the tires to fill the wheel well. Before I did this, the car looked as if it had a lift. ![Smile](https://camaroforums.com/forum/images/smilies/smile.gif)
The two obvious solutions to prevent this rubbing would be to 1) put in smaller tires or 2) replace the springs with ones I didn't cut. However, is there anything else I can do to prevent them from hitting the fender? For example, is it possible to get a larger a-arm bumper?
What size and series tires are you running? I guess you could get a larger bumper, but that seems more like compensation, than a real fix. So those 8's in the front aren't rubbing the sidewalls of the tires on your steering linkage? To get around the open wheel well look I swapped out the springs for Eibach 1" drops, then went to a 17 x 7 wheel (also put in baer brakes...I was there already, why not). No doubt, the stock set-up with 14" wheels leaves almost 5" of space between the top of the tire and wheel well lip....not a sporty look at all.
You have a nice ride, I don't think you would regret slapping a pair of Eibach on it and it will give you a good rake.
We did it with Hotchkis springs which droped the front end 2" and went with 17x8 rims with a 215/50 R17 tire size. Unlike the stock springs which have several inches of pre-load, these springs have very little pre-load. Basic inprovement is the wire size of the spring and high quality steel which gives a firm but not harsh ride. I think you'll like the look and the improved suspension.
Nice Ride!
Good Luck...
Nice Ride!
Good Luck...
I have the same problem with the tires and rims I just purchased. I had 14" rims and replaced the drums with disc and moved up to 15" and 225/60 R15. My passenger front tire rubs the back of the wheel well when I turn right, but the driver side is fine. I also hit the top of the fender when I hit a bump. I believe my bump issue is the type of rims I have. The tires mount outward from the rim (Chaos 5s) and stick out a little bit from the well. I am going to go with a smaller tire....1" less. I may have to increase my springs also. Not sure if 1" is going to work.
how new are your shocks in the car? i had a good tire rub on my 68 when i would hit a bump and the fix was putting on a new set of shocks on the whole car. i have just stock rallyes with diamondback red line radials.
Now I'm debating if I want to get the Hotchkis or Eibach springs or just installing spacers to fix the rubbing issue.
Well, I got really tired of the rubbing tires. Someone at a car rally suggested that I use spacers, so I went to autozone and got a pair of these for a quick short term, cheap solution :
http://www.autozone.com/autozone/acc...er=540609_0_0_
Yes, yes, I know... I cut off half an inch from the springs, then I add an inch using spacers.
However, it did solve the problem. My tires no longer rub, though they do sit up a bit higher. I think in the long run, I may end up getting stiffer coils or something.
