Rear quaters
RE: Rear quaters
ORIGINAL: 68RSSScamaro
But if you do replace these, a little trick I would share is to use self tapping sheetmetal screws to secure the quarter before final welding. By using screws to prefit the panel you are able to easily adjust the quarter before final weld. When you have the panel properly placed tack it and then remove one screw at a time and weld the hole shut
libertyforall1776
11-10-2007 03:04 PM
