Rear Diff
Changing out the brakes on a 69 Camaro to disc. I need to remove the rear axels yet I cant figure this one out on how to remove them. I cant even figure out what diff this is. It also dose not appear to have C-Clip eliminators.
https://cimg8.ibsrv.net/gimg/camarof...2cc03c427f.jpg https://cimg9.ibsrv.net/gimg/camarof...313d96adf1.jpg |
10 rear should be like this:
(Post 746339)
https://youtu.be/3t1jmPfTdQE |
Originally Posted by rgraze
(Post 746340)
Unfortunately my diff does not look like that as you can see in the pictures. Wish it did. I have some sort of after market diff that I cant ID.
If not it must have c clips in there. There's no way to release the pin holding the shaft for the spider gears? |
Thanks for the help. there was no pin for the spider gear. I put a drum on backwards and hit it with a hammer. I just didnt think GM 10 bolt had a setup like this, kept looking for a pin and c clips.
(Post 746345)
Did you get the axle out? |
(Post 746346)
Well it's probably an aftermarket differential inside a GM 10 bolt rear end but what make ?
(Post 746347)
Yes I got it out fairly easy, just a couple wacks. I still have no idea what kind of diff it is.
If memory serves I had an old '60's1/2 ton pickup like that but my memory is questionable. lol |
| All times are GMT -5. The time now is 04:41 AM. |
