Rally Wheels??
Rally Wheels??
Hey guys, newbie here to the camaro forum..I just picked up a 67. The car came with 14 inch rallies on it...I did a disc conversion on the front, and I was told the calipers will rub the 14 inch rims.. I just bought a set of 15 X 7's for the front, and I am going to run 15 X 8's in the rear..My question is? What size tire would look best on the car, I want to keep everything under the fenders and quarters..without rubbing...I would like alittle wider tire on the rear..Any suggestions
Thanks
Steve
Thanks
Steve
I used to run a L-60R15 or 275/60R15 tire on an 8" rim on the rear of my 68 Camaro. One thing, make sure your springs/ shocks are good because they can rub the wheel well if you get to much weight in the back seat.
I forget what I had up front, but maybe something like a 235/75R15 would work for you with a 7" rim or even a 255/70R15.
