Rad cap / coolant level
I checked my coolant level the other day and saw it was a good 6" below the radiator cap throat so I added some. I filled it to the top and then had it overflowing back out the overflow tube after the first long run. It's now down to about 2 or 3" below the rad cap throat. Is this normal or, is the spring in my radiator cap going and needs to be replaced?
The current cap on it is a 13lb cap.
Thanks.
Thanks.
Not unuusual for the coolant level to be down an inch or so, but if it continues to expell the fluid to 3" or more I'd start with a new cap. Does your engine run hot?
evilbeef54
Jul 27, 2008 09:47 PM
